Orange light on PV500.
Discussion in 'Plasma TVs Forum' started by Rapid 17, Jul 31, 2005.
  1. Rapid 17
    Rapid 17
    Jan 14, 2005
    896
    28
    +79
    I recorded Top Gear this evening and started recording using the direct tv rec buton on the remote control for my DMR-ES10. When the programme finished i stopped the recording, switched off the dvd recorder and put the pv500 into standby mode. The red standby light came on as usual but the orange one was also on. Does anyone know why the orange light came on please ? Geoff.
  2. bin_man
    bin_man
    Feb 24, 2005
    23
    Have you checked if you have another program programmed to record on the Plasma ie.selected via the 'guide' ?
  3. Rapid 17
    Rapid 17
    Jan 14, 2005
    896
    28
    +79
    I reckon i used the wrong record button. The orange light is not on today when the pv500 is on standby.
