Razor
Outstanding Member
- Joined
- Dec 15, 2004
- Messages
- 37,733
- Reaction score
- 12,416
- Points
- 6,866
Look at the judder issue the other way round.
Say for example you are used to seeing smooth playback on a large screen. You then change the screen and the smoothness is gone and replaced with judder/jerks. It will be instantly noticeable. The difference between a £800 dvd player and a £80 isnt just multi formats (dvd-a, cd-r, divx, etc) as the cheaper players normally out do the expensive players on this department. The difference is in the refinement of playback of a dvd to give a crystal clear, smooth motion picture with true colours, sound etc....
I am sure after a few weeks of powerstrip/reclock you will intantly notice judder if you forget to put it on.
On reclock there is a option to sync the sound to the pic. You can also do interlaced or non.
I think I know where your going wrong with powerstrip. Just enter 49.83 into the vertical geometry and leave the scan rate. Ok it and exit it, when you go back in the scan rate will be adjusted automatically. Dont try and set them both yourself, they are directly linked.
Let me know if you have success
