Optoma HD91 Reviewer's Recommended Best Settings
Discussion in 'Projectors, Screens & Video Processors' started by Steve Withers, Jan 30, 2014.
  1. Steve Withers
    Steve Withers
    Reviewer
    Oct 18, 2009
    9,985
    +9,624
    Disclaimer: The settings below are supplied for information purposes only. We make no guarantee that using the adjustments below will improve your TV's picture, they may even make it look worse. Every TV, even from the same manufacturer and model number will vary, as will the environment the TV is used in. For further information on how to set up your TV, please follow the steps in our Picture Perfect campaign.
    To find a professional calibrator near you, see our Custom Installer and Calibrator Directory.
    You can read the review here: Optoma HD91
    Display Mode: Reference
    Contrast: -12
    Brightness: 0
    Colour: 0
    Tint: 0
    Sharpness: 8
    Advanced
    Gamma: Film
    LED Brightness: 100%
    Colour Settings
    Colour Temperature: D65
    Colour Gamut: HDTV
    Colour Space: Auto
    RGB Channel: Normal
    RGB Gain/Bias: Red Gain -1, Green Gain 0, Blue Gain +2, Red Bias -2, Green Bias +2, Blue Bias -3
    CMS: Red (X Offset 0, Y Offset -5, Brightness -13), Green (+1, 0, +50), Blue (-2, -9, -5), Cyan (+3, +12, +13), Magenta (-3, -10, -8), Yellow (-3, +4, +17)
    Pure Engine
    UltraDetail: Off
    PureColour: Off
    PureMotion: Off
    Display
    Format: Native
