Garibaldy
The HD82 is currently available for £1169 with 3 years warranty but i'm not sure it meets my physical room requirements. Please can you offer any advice?
This is for a new setup with a ceiling mounted projector and I'd like a diagonal image of 106". The width of my room is 13" 6' and it appears that i need a 16" offset from the top of the screen (my ceiling height is 8" 1').
Will the HD82 fit and which mount would you recommend?
