digibrowser42
I have an Optoma HD82 projector which shut down about 5 minutes after starting up. There's a trigger to the screen which stayed down. The sound still played through the amplifier - the picture also goes through the amp - I checked different sources and they all came up blank.
The screen went black and a solid orange light appeared on the side panel. I checked the manual which suggested a lamp fail (a bit strange as there's supposed to be a warning before it fails)
I changed the lamp with a genuine Optoma bulb and it still won't work. I've turned off the power, unplugged the projector from the mains and still nothing. It powers up, the blue light comes on, the fan whirs and then shuts off then the orange light comes on.
Does anyone have any suggestions as i'm scratching my head a bit?
