optoma hd7oox connections & reciever
donthaveascooby
HI, i am looking for an av reciever to connect up to an optoma hd700x projector with s video,vga,component,composite,usb & hdmi.I want to connect it to sky plus(possibly hd),x box 360,wii & dvd.Can you advise me of a decent priced reciever that would be fairly future proof and provide me with good sound and vision.Would i connect the reciever to the projector with an hdmi lead only and connect the rest to the reciever? If so what connections would i be best using for connecting the above as i will be neading 5 mtr cables for each connection.Cheers
McPhee
  1. Budget
The biggest choice you're going to have to make is whether you want all of your connections being sent to your projector down a single HDMI or not. Generally speaking you won't find an AVR below £300 that will do that. If you aren't too fussed about the reciever doing that then you can get a pretty well spec'd machine for below the £250 mark (something like the Sony STR-DG820).
I faced the same desicion and decided i needed that feature (called 'upconversion'). More cables = more mess, and decent cables aren't cheap either. By the time i'd factored in cable cost, the extra hassle of running 4 sets of cables from amp to projector and the extra features and performance at the £400 mark the choice became pretty clear.
donthaveascooby
spelling and grammar were never my best points. As a twice european kickboxing champ though, nobody has ever bothered me with it much ! cheers anyway mate
Lee
McPhee.... I think you're being a bit harsh about the grammar, I personally had no trouble reading it.
donthaveascooby....I have moved your thread to the receivers as I think it will be a better forum for you to get advice.
