Question Optoma HD65 Replacement Bulb
Discussion in 'Projectors, Screens & Video Processors' started by flamingo294, Apr 20, 2016.
Tags:
  1. flamingo294
    flamingo294
    Dec 28, 2014
    11
    Weymouth
    Hiya,
    My HD65 turned itself off the other day and now won't turn back on. The bulb does not turn on so I'm assuming it has gone; the thing that worries me is a slight high pitch noise on startup which I'm assuming could mean damage to the DLP colour wheel.
    Does anyone have an old bulb that they don't need so I can try it before ordering a new one? I'm not bothered by how many hours is on it, just that it will power up properly for me to diagnose if it is the bulb or colour wheel.
    Many thanks,
    Andy
