Hi, first timer here and new to projectors.
Went to use my hd600x last week and the bulb blown light came on and nothing else. removed the bulb and cleaned out some dust and it started to work again. Now every now and then it says the bulb has blown again but by unplugging it and plugging it in again the fault goes.
If the bulb had blown it obviously would never work. Does it check resistance in the bulb? don't want to splash out £100 and still get the same problem.
Any help appreciated!
