Matthew Legg
The lamp on my projector blew with a loud bang. I ordered a new lamp optoma lamp and fitted it according to a guide. The projector powers up normally with no warnign lights but no light comes out now.
Is it possible the bulb is faulty and is there any way to check?
Is it possible I just wired the bulb the wrong way and if I swap the cables could I risk blowing it?
Is there any way to check if there is more damage or a blown fuse in the projector?
Any help would be really appreciated.
