Hi, my trusty optoma HD33 started giving a fan failure error then turned itself off. So I took it apart and checked all 3 fans are functioning which they are
Unfortunately after putting it back together I'm getting no picture not even the graphics or menu. The bulb is working fine, and I can turn it off with the remote just nothing is being displayed. Have I broken it?? Is there a hard reset button on this PJ?
Thanks.
Thanks.
