Optoma HD230x vs HD23 differences?
Mensy
Does anybody know the differences between these two PJs
TIA
In my experience. The X Versions Tend To be the same as the none X Versions if you get me.
Its Black and will probably only have 1 years warranty instead of White and 3 year warranty.
In my eyes
HD23 And HD230x are the same
just like
HD33 And HD300X
And
HD25/HD131x
Optoma seem to do it alot, they maybe the odd light difference but im sure there all identical to each other
BRADY4GOAT
A dealer once told me that they use cheaper parts in the 230x ect and the quality of the isn't as good, 3D isn't as good nor is the picture hence the price difference but that might be down to the cheaper parts. The warranty is also a lot less. Usually the 230x ect is £150-200 cheaper
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
