Optoma HD141X projector to replace current?
Discussion in 'Home Cinema Buying & Building' started by Wall E, Jul 14, 2015.
  1. Wall E
    Wall E
    Jan 8, 2013
    16
    4
    Hey all. I currently have a Mitsubishi HC5500 hooked up and Im wondering if its worth swapping for the Optima. Im not expert as the Cinema room was already set up when I bought the house with the Mitsubishi, hooked up through a Sony STR-DG820 amp (If I need to take that into consideration at all).
    Can anyone help?
  2. citywalker
    citywalker
    Mar 7, 2012
    819
    46
    +142
    You can't just pick random projector. Did you check distance vs projector screen size?
  3. Wall E
    Wall E
    Jan 8, 2013
    16
    4
    I didnt. What else should I look for? The projector is only 10 foot from screen.
  4. citywalker
    citywalker
    Mar 7, 2012
    819
    46
    +142
  5. Wall E
    Wall E
    Jan 8, 2013
    16
    4
    Ok. Using that site I think it would work as a replacement but I'm still not sure. Is there anyone on here that would be able to let me know? Just because the Optima model is the one being offered
