Optoma H57 noise level
Discussion in 'Projectors, Screens & Video Processors' started by knightman, Jun 21, 2005.
  1. knightman
    knightman
    I bought this projector for its top class reviews and the quoted noise level. In all respects it has lived up to expectations apart from a slightly irritating low level buzzing noise that is audible in quiet scenes. I would have expected to hear a low level fan noise but this seems a bit more whiny than that. Has anyone else experieienced this?
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,153
    UK.
    +2,671
    It might be the colour wheel - they can make a bit of a buzzy sound especially if they're of the larger variety. If you change between NTSC and PAL DVDs, does the noise change? The colour wheel should slow down for PAL.
    Gary.
  3. knightman
    knightman
    Thanks Gary , will try that and see
