rimibar
Established Member
I have recently borrowed an Arcam DV79 to use with my Optoma H50 projector, and am having a few setup problems with it. I am hoping that the forum members might be able to help.
I want to connect the Arcam DV79 via HDMI to my H50. As the Optoma has a DVI socket, I have borrowed an HDMI > DVI converter.
When connected in this manner I get a message saying "HDMI connection not found". The "Force DVI" option does not make any difference.
When I select HDMI as the output option the image doubles up on screen. When I switch off the progressive option I get a red tint across the screen.
I spoke with Optoma who simply said that you could use HDMI, but as the signal is being converted and something is being displayed, then I am inclined to believe that there may be hope yet.
Any suggestions would be gratefully appreciated!!!!!
