Optoma H31/H30A
Discussion in 'Projectors, Screens & Video Processors' started by healyj25, Jun 16, 2005.
  1. healyj25
    healyj25
    Hi, considering buying the OptomaH30(In the US), has anybody come across issues playing 'pal' material through this..the spec looks the same as the H30A(europe)
  2. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    Stick with H30A, warranty issues with the US version you would have to send it back to the US if any problems, also the H30A is optimised for Pal.
  3. healyj25
    healyj25
    Thanks for the reply Neil, but I purchased the H31 before reading this post. Luckly I've not seen any issues playing PAL Material, I am however worried about warrenty etc...
  4. cybrey
    cybrey
    Apr 21, 2005
    572
    +64
    H30A / H31 - are the same projector, H31 is the US version, H30A is the european version, other than the plug I don't think theres any difference between them. H30A / H31 has a 16:9 native resolution at 480, so as said above I'd have bought the H30A but purely from a warranty perspective.
  5. healyj25
    healyj25
    yes the warrenty is the only worry, but I did save 600 euro by picking it up in the US, one quick question, I'm trying to source the '15 pin D-sub to 3x component adaptor' that comes with the H30A....
