Optoma H30A
Discussion in 'Projectors, Screens & Video Processors' started by chestnut, Mar 4, 2005.
  1. chestnut
    chestnut
    Jan 27, 2005
    59
    Does anyone know if you can ceiling mount the optoma H30A, and any brackets that would be appropriate for a 500mm drop?
    Many Thanks
    Chestnut
  2. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    5,031
    Lockerbie, Scotland
    +943
    try these people...
    http://www.lmp-pc.co.uk/mount.shtml
    They don't seem to have a specific mount for the H30A but they seem to offer free mount if u will let them take a footprint from your projector. Worth a try I suppose.
    I use their mount on my AE700 and am very happy with it.
    Regards
    KH
  3. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    Yes the H30A can be mounted, will have a look at the size and drop of our free ones
  4. chestnut
    chestnut
    Jan 27, 2005
    59
    Ntslik
    Have looked at your companies web site a few times with interest but can never find any details of the free ceiling mounts you offer. With my particular set up i need a specific drop to avoid a hanging light, and throw the image at a decent viewing height.
    Any details you have would be appreciated.
    Kind Regards
    Chestnut
  5. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    can do one with a 475mm to 775mm drop
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,917
    The Borders
    +3,569
    Chestnut
    If LMP cant sort you out the Unicol Gyrolock is a firm favourite with our install teams - there are four adjustable leg length columns available for the Gyrolock so 500mm is not an issue.
    Like most modern projectors the H30A is easily ceiling mounted and the User Menu includes an option to flip the image for floor or ceiling mounting and front or rear projection.
    The H30A has IR pickups on the front and rear of the unit so even if you ceiling mount close to a rear wall the IR works - usually you can simply point the Remote at your screen.
    Keep in mind you have to work out where the Projector can live in relation to your screen - don't assume you can simply put the projector at the back of your room and get an image that fits on your screen.
    Best regards
    Joe
