Optoma h30 ceiling mount
Discussion in 'Projectors, Screens & Video Processors' started by kennyb, May 23, 2005.
  1. kennyb
    kennyb
    Apr 29, 2003
    58
    scotland
    Can anyone recommend me a adjustable ceiling mount for h30 and where to buy it?
    thanks
  2. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +191
    Hi, I have recently used a LMP mount for mine. Good price, easy to install and I think (as does my wife...Phew..) looks really good.
    If you have a search around you'll find a lot of recommendations for them.
  3. Crivens
    Crivens
    I bought the Vogel universal ceiling mount. I got the second one in the link below. Same price, and you also get an extension too. Didn't actually need it, but you never know in the future. I bought mine for a HS50, but is supposed to work with most projectors. Works fine.
    http://www.avrabbit.com/products.asp?hdnTable=MH&SecBus=1
    Oh, and it only took a couple of days to arrive from ordering online too.
