Question Optoma 3dxl download link - hd700x firmware
paulbed4d
So I seem to have found the link to update the hd65 firmware
Am I right is assuming that's the same as the HD 700?
In the instructions it says to use a laptop running xp or vista's. It says windows 7 isn't supported.
My lap top runs windows 10. Any idea if it's going to work?
paulbed4d
So it seems that it works on windows 7 although a little fiddling is needed to get it to connect. I hope it works on Windows 10!
paulbed4d
So I've downloaded the software and managed to install it on my lap top.
There are two programs
installdriver.exe
flasher.exe
I ran the install driver program and a dos window popped up for about 5 seconds, then went off.
I then connected my PJ to my laptop in service mode.
When I run the flasher.exe program to update the firmware it just says my projector isn't connected.
I just cant get it to recognise its connected.
Can anyone help?
paulbed4d
I've got this sorted. I took it to a local computer repair shop and they plugged it into a vista PC and updated it for me. Thanks
