Optoma 141x colour wheel
Discussion in 'Projectors, Screens & Video Processors' started by Seasider25, Nov 8, 2017.
  1. Seasider25
    Seasider25
    Nov 8, 2017
    2
    Kent
    Hi, have a Optoma 141x colour wheel which has thrown its black signal detection spot.
    any idea exactly oposite which colour it should be next too, on the rotor . Any Help would be great, otherwise its keep trying options. thanks
  2. unreel
    unreel
    Dec 25, 2008
    558
    43
    Manchester
    +243
    A google turns up a possible result on ebay, no idea if this helps or not.
    ORIGINAL & Brand New Color Wheel for OPTOMA HD141X HD180 GT1080 HD230X | eBay
    * Usage: Signal detection point is under the blue color(5mm); Before installation, checking that the position of the black stick point is the same as your color wheel, Or manually pasted to a consistent location.
  3. Seasider25
    Seasider25
    Nov 8, 2017
    2
    Kent
    Hi thanks, i did see this on ebay,however they say check its in the same place as my one, if not move the detection point so it corresponds with my original one. i thought of buying this at first then thought i may be back in the same position as i am now. Thanks for info though.
