Options?
Discussion in 'Cables & Switches' started by WScarlet, Aug 14, 2004.
  1. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    Hi on my plasma/tuner box i have 1 rgb scart socket which i need to connect my playstation2 and sky upto, so i bought a scart switch box from argos the ones u all recommend only to find out it doesn't work with my plasma :( tried it on my lcd portable tv works fine, have you guys got any other suggestions?
