Options to connect up PW7
Discussion in 'Plasma TVs Forum' started by tamthetim, Nov 8, 2004.
  1. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    decided on buying a PW7 instead of the 6 so in the future I can buy the appropriate input board and HDMI dvd player (when they are cheaper and readily available)
    just don't know what input boards to buy, getting conflicting information?
    options I've read from the various threads
    1) PW7 with component and RGB scart
    dvd (tosh existing) to plasma with component cables
    sky digibox to plasma with RGB scart
    2) PW7 with 1 component board only
    amp (yamaha V620 existing) to plasma with component cables
    dvd to amp with with component cables
    sky box to a converter with rgb scart
    converter to amp with component
    3)PW7 with 2 component boards
    dvd (tosh) to plasma with component cables
    sky digibox to converter with RGB scart
    converter to plasma with component cables
    People also talk about VGA connections which I think are standard on the PW7. I'm just for the best picture available with sky and dvd and not looking to connect up any other equipment. I,m happy with the audio side from my amp with a Mission M74 surround sound package.
    I've read that scart to scart is "soft" but any opinions on the best option would be most appreciated, or a new one.
    thanks, tam
  2. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    All those options sound viable - you've covered all the main points of view on this forum anyway! :)
    There is a reasonable market for second hand JS Tech convertors - so if you do go that route and then change your mind you can sell on on here for only a little loss.
    Personally I went for the convertor straight to VGA input as i don't have a AV amp ... just a Sony DAVS550 - which i use for sound only as it doesn't have component or scart in :(
    ZedZed
    p.s. It might just be me ... but I think that the already good PQ on the panel gets better after the first fwe weeks. Might be a "placebo" effect though ....
  3. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    thanks zedzed
    thinking of heading down the route of 2 component boards with the pw7 and convert the scart to component for the sky digibox.
    I've read other recent threads that say to stay way from the PW6/7 scart input boards.... as their not up to much.
    any other opinions most welcome....espicially about losing PQ by taking component through amps?
    cheers, tam
  4. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    changed my mind yet again after reading other threads...........going to order........PW7 with one set of component connections for dvd...............order a JS Tech RGB to VGA for the sky box - hope this is better than scart to scart
  5. Yorkieblade
    Yorkieblade
    Me again Tam sorry mate, I think we are at the same crossroads as you in the plasma stakes.
    I have a Kenwood KRF- 5050V 5:1 AMP
    Sky / possibly gonna get Sky+
    A cheap and nasty Accoustic Solutions DVD player which I can upgrade if Necessary
    PS2
    PC
    Any idea ? what would be best pw6 or 7 ?, and which boards do I need and how much extra are these boards are are they free with a pw6/7?
    Scratching head lol !!
    Yorkie
  6. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    yorkie..........think i'm only about a day ahead of you in the knowledge stakes...............but it looks like you need exactly the same as me........if you go for the PW6/7
    only thing is i have a tosh dvd player that has component connections...........but yours might not....the pioneer 575a is highly recommened by most for an upgrade
    I'm buying
    PW7 with free component board
    JS Tech RGB to VGA converter
    set of xcomponent cables
    VGA lead
    already have a decent scart for the sky to converter
    wall mount.tilting?
    my mates going to buy the same.....we're hoping to do a deal with av sales, but crystal have the PW7 at £1795 including comp board and free delivery.
    hope this helps
  7. Yorkieblade
    Yorkieblade
    Thanks Tam, great info mate. there is not much in the price then really between a pw6 and 7 . AV- sales have quoted 1580 quid for pw6.
    One little query I have sent to me on a previous thread is that do any of the pw6/7 allow good resolution for a pc? i.e 1024 x 768 as opposed to 852x480 SD Display ?
    regards
    Yorkie
  8. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    sorry mate..........know sweet fa about that sort of thing.....................mines in a different room and not getting hooked up.................but sure others will advise..........cheers
  9. Yorkieblade
    Yorkieblade
    If you don't mind me asking Tam how much did this lot come too please?
    VGA lead
    wall mount.tilting
    I would not need tilt facility on wall bracket though .
    Regards
    Yorkie
  10. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    should be about 2,100 approx....but my mate was e-mailing a few companies tonight to get quotes.....so i'll let know when we get them in later in the week.
    PW7 with comp board 1,800
    jb converter 120
    comp cables 40
    vga lead 20
    wall bracket 120
    tam
  11. Yorkieblade
    Yorkieblade
  12. Yorkieblade
    Yorkieblade
    Thanks for price Tam.
    Is yours in black or silver?
    I prefer silver myself
    Yorkie
  13. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    silver........sometimes you can pick the black ones up cheaper
