Options Please! - replaceing RAV180 remote
Discussion in 'Home Cinema Control & Remote Controls' started by MrSimba, May 20, 2005.
  1. MrSimba
    MrSimba
    My Yamaha RAV180 remote has died, and as such I cannot reprogram a learning remote with it,
    What are my options and what do you recomend?
    Are there data banks of remote codes on the net? and what replacement remote should I go for?
    I have DVD, SKY+, PW6 Plasma, DSP A2 amp, all to go into it f I go the 'all in one' route and I'm not *too* worried about cost just want the best solution!
    Cheers!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    harmony H655 now available for £50!!! :eek: uses an online database so you just download the codes you need :)
  3. anirac
    anirac
    Hello Mr Simba, I have a Yamaha RAV 160 remote control that is in new condition, I am not sure what the difference is but I will try to find out. Feel free to email me at marano1999@msn.com with any questions
    Regards,
    Ron
