Gallifreyan
Established Member
Hi all
My trusty Panasonic Ex768 is on the way out. Error codes U61 & 88 are happening all the time and the drive is whirring and clunking with it.
My Sony bluray player (740?) is also aged and buggy with few seconds of sound or picture/connection loss
I would like advice on replacements.
I have been looking at the Panny bwt550 which combines the two. JL & Richer Sounds are playing games with the price yoyoing between £235 & £279.
What about a PVR and separate bluray player? Any advantages?
My current Smart setup is an non-hard drive You View box courtesy of TalkTalk. Can be buggy, taking a while to load catchup and EPG. Not sure how or if it compares to Freview Play.
Darren
Darren
