I have a pretty unusual (and frustrating) issue with my projector.
I use it mainly with my PlayStation 2 and use that to mostly play Playstation 1 games - bit of a retro junkie in that respect. Until today i was using it with composite AV and everything was fine, but have now decided to upgrade to component connections.
Only after I bought all the bits to do this do i find out that there are problems displaying the PS1’s 240p resolution over component. The issue is generally whether the TV/projector will accept it. Mine apparently doesn’t. It’s an EUG one I bought from Amazon. £400 so not the cheapest, but far from the best, I know.
Here are my options: 1) ditch the PS2, buy an original PS1 and a special adapter you can get. Not 100% sure this is viable, whole thing I’ve been looking at has a chance of being snake oil.
2) Buy a PS3, which also runs PS1 games but also upscales them. Problem is I also have to buy a rare memory card accessory so i can use my save files on the PS3, or else ditch a couple of years of ‘work’. These memory card accessories cost as much as PS3 console itself and are pretty hard to find.
3) Swap the projector.
So, I’m leaning on option 3, and thinking about maybe a CRT projector, like a Seleco SVT 150, for example - but not sure if that would even have component connections?
Pretty lost trying to Google all this, so I’m very much open to suggestions. End result being, ideally, to play my beloved PS1 games at the best possible quality, 6ft wide on my living room wall!
Thank you!
Thank you!
