Options for Blu-Ray to SD TV
GazH
Hi All,
Starting to get problems with my DVD player (Pioneer DV-575a) as it either takes ages to load some DVD or (as with Skyfall over the weekend) just doesn't recognise it.
I updated to firmware 2.13 but no luck :(
So, I have been looking around and think the best option, if I upgrade, would be to get a Blu-Ray player to future proof until for when I get a HD TV (current TV a Panny 37PE30).
The player that seems to fit into my budget with best features seems to be a Sony BDP-S490.
This only has a HDMI out (not surprisingly) but the best my TV will take is component.
Have seen some cables that do HDMI->component but these just don't work and have also seen HDMI->component converters but these can be expensive.
So, what options do you think I have? Maybe other players? alternative ways to connect?
Unfortunately the option I don't have at the minute is upgrading my TV.
Many thanks in advance
Gaz
I think upgrading your TV is the only one thing that needs to be done to fix the issue as you have tried everything, but nothing is working. If it is not possible to upgrade your TV, then perhaps you need to contact their service team to help you out.
GazH
Hi maryancell001,
Thanks for the reply.
So, if I bought a Blu Ray player are there any options for me playing it through my TV using Component?
Many thanks
Gaz
mentm
Some older players had component, but they haven't been included for a number of years, and they would only output 480p. Other option you have is something like the hd fury which converts the video and are expensive.
GazH
Yeah, thought that may be the answer :(
Outputting at 480p is fine, would just like to be able to use my current TV until it "expires" :)
Thanks for the replies
Gaz
FieldDE
PS3?
Component cable from the multi-out, then HDMI when you get a new TV. Also gives you playback from USB drives and media servers, plus iPlayer/4OD/Lovefilm/etc.
nvingo
If it's only for a temporary arrangement pending new TV, I'm certain that the composite video output on the BDP-S490 would provide a signal compatible with the inputs on any SD TV.
Terminals
HDMI Output 1 (Rear)
Component / Composite Video Output 0 / 1(Rear)
Coaxial Audio Output / Analog Audio 2ch Output / Analog Audio Output 1 (Rear) / 1 (Rear) / 1 (Rear)
Ethernet 1 (Rear)
Front/ Rear USB 1 (Front) / 1 (Rear)
From the online manual page 10, use the [1] LINE OUT (VIDEO) jack and the [6] LINE OUT (R-AUDIO-L) jacks
(or [7] DIGITAL OUT (OPTICAL) jack) to connect to the scart/video in on the TV (or audio in amp).
Wild Rumpus
PS3?
Yes, that's what I use, I was in the same position as the OP - It works fine!
