Optimum Viewing Distance-Any opinions?
Discussion in 'General TV Discussions Forum' started by Anastie, Jul 23, 2003.
  1. Anastie
    Anastie
    Jul 15, 2003
    1,960
    63
    UK
    +208
    May sound like a dumb question but I am wanting to upgrade my Toshiba 28W8DB with a 36" or 32". I really fancy a 36" to go with my digital sound set up but apart from all the debates surrounding the PF2 and PD30 my other concern is the distance from TV to chair as I d not want to spen up tp £2000 on a TV that is uncomfortable to view. My max viewing distance would be around 11 ft. Or does it not matter nowadays with the (supposed) quality of TV's.
  2. shaunthedude
    shaunthedude
    11 foot is ok. I have a 44 inch and sit less than that away from it and its great.
    shaun
  3. Bogside
    Bogside
    Sep 20, 2002
    3,141
    Stockport (ex Derry)
    +418
    I've always believed that the optimum distance should be something like 2 and a half times your screen size. So for a 36" screen that would be 90" - or 7 and a half foot. So you should have no problems.
  4. Zor
    Zor
    Mar 17, 2003
    185
    19
    Cheshire
    Or work it out yourself here
  5. Anastie
    Anastie
    Jul 15, 2003
    1,960
    63
    UK
    +208
    Thanks for the quick response
