Optimum resolution for SVID out to CRT
Discussion in 'Desktop & Laptop Computers Forum' started by CodeThief, Nov 10, 2003.
  1. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Hi there,
    I've just got my HTPC up and running (in a temp case :D )
    I'm running 1024x768 from a Radeon 9200 Svid into my Panasonic TX28PK2 Widescreen TV.
    Is this the optimum res to use or should I be configuring something with Powerstrip etc? What refresh rate??
    I use WindowsXP MCE and PowerDVD for DVD playback.
    Dave
  2. Kramer
    Kramer
    S-video - not really the intended use for a HCPC.
    Have a look for TV Tool.It's probably the most suitable software to use with (poor quality) s-video out.
    Oh.....nearly forgot, get a projector or plasma :)
  3. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Thanks for the reply.
    Im using a Radeon and therefore can't use TVTool. What are you calling Svideo poor compared to (the Svideo out I was using from my old Panasonic DVD player??) ;) Trust me the picture is just as good if not better via Svid on the Radeon than my Panasonic Box.
    Still, you didnt answer my question, what resolution should I be using and what refresh rate?
    Oh almost forgot, can't afford £3k for a plasma / projector or have the room for them!!!!! :(
    When you say Svideo isn't the intended use ... what IS the intended use?
    Dave
  4. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    Try 848x480.
    MuFu.
  5. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Thanks Mufu. Any reason why I should use this res??
    Sorry, I've just read my previous post and it seems a bit agressive. Sorry thats not how I meant it to come across.
    Dave
  6. Kramer
    Kramer
    HCPC's are usually connected to display equipment (digital/analogue projectors & plasmas) via either VGA or DVI.
    S-video is far inferior to either.
    AFAIK, you're restricted by using s-video. Don't think you can select different resolutions/refresh rates (well, not with Powerstrip anyway), being limited to standard "PC" resolutions, VGA, XGA etc.. Hence my recommendation of TV Tool.
    HTH.
  7. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Oh well I'll have to put up with it until I can afford a projector :)
    Thanks, I''ll dig out Powerstrip and play with 848x480 :)
    Dave
  8. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    You'll probably find it's the highest, approximately square-pixelled res you can get away with on a widescreen CRT (856x480, 960x540 and 1024x576 never worked for me). The aspect's a little off but that can be corrected using the geomtry adjustment in Powerstrip and/or the vid card drivers.
    MuFu.
