Optimum 1:1 pixel matching on panasonic 42pw4
Discussion in 'Desktop & Laptop Computers Forum' started by perrin21, Nov 2, 2003.
  1. perrin21
    perrin21
    Sep 30, 2003
    221
    Preston
    +16
    anyone know the best powerstrip settings for this screen 852 x 480. although this is not divisable by 8 i was led to believe that my parhelia can do this, is this true? What settings should i use for 1:1 mapping?
  2. perrin21
    perrin21
    Sep 30, 2003
    221
    Preston
    +16
    anyone
  3. perrin21
    perrin21
    Sep 30, 2003
    221
    Preston
    +16
    OK problem solved, i have just successfully managed to get 100% 1:1 pixel matching through the VGA input using Matrox monitor manager. 852 X 480 even though 852 is not divisable by eight. I know now i made the right choice with the Parhelia as it is the only card able to do this. I have checked this using the the background available from the FAQ. There is no banding at all.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,150
    Why the big deal about divisable by 8?
    You seem very keen on your parhelia.
    I get 852x480 no problem with my Radeon VE and powerstrip.
    I think you'll find plenty of people on the HTPC forum with no problems getting that resolution on a wide variety of cards. The key thing is powerstrip.
