Optimal settings for Pixel+ ?
Discussion in 'General TV Discussions Forum' started by Hyzepher, Nov 13, 2003.
  1. Hyzepher
    Hyzepher
    I have just got a 36pw8618 and I have to say that the picture is stunning. I was wondering if any of you already have this model or the 9308 and can let me know your optimal settings - just to be sure that I have it set up the best way possible. With Pixel+/Movie+ etc it can be a bit daunting.
    Hyzepher
  2. davidgirecourt
    davidgirecourt
    I can only comment on my 32pw9327.
    My settings are:
    Contrast 75
    Brightness 34
    Colour 45
    Sharpness 0
    Not far away from factory settings by the way!
    Sound is up to you
  3. Russell_S
    Russell_S
    Sep 29, 2003
    134
    Waterlooville
    +10
    I have just got home with my 32PW9308 and installed it. I have to say that the manual is pretty crap and gives no guidence at all about the pixel+ / movie+ features etc. All it says is where they are in the menus but no info about what they do etc.
    Russell
  4. Hyzepher
    Hyzepher
    I did some searching on the forum and after a while I found settings posted by rct - tried them out and 'wow' tv is even better now than before. Settings can be found here
    I must say that when I decided to get the 36pw9618 I was nervous when I turned it on - especially after reading the comments about Philips tv's on this forum. Initially I was disappointed with the picture but then realised that I was viewing it from far too close. I sat about 2 -3 feet further back and voila the picture was perfect. I suppose the large the TV the further back the optimal viewing distance is. I have subsequently adjusted my furniture to ensure that everyone has the best picture.
    If you have a small room I would think twice about buying a 36" or even a 32" if the room is particularily small.
    Hyzepher
