Optimal combination of Gallo speakers
Discussion in 'Home Cinema Speakers' started by d_elad, Jan 12, 2003.
  1. d_elad
    d_elad
    Jun 27, 2002
    Israel
    Greetings
    I am about to install an HT system based on Gallo speakers (music, especially classical, will be occasionally played on the system). I am considering the following options:
    1. 6 A'Divas
    2. 3 A'Divas (front)+3 Nucleus (rear)
    3. 2 A'Divas (front left, right)+4 Nucleus (center, rear)
    I already have a REL200 sub and Denon 3802 receiver.
    I would appreciate suggestions regarding the optimal combination based on price/quality considerations.
    Danny
  2. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    Not an easy one to answer as the A'Divas are not yet on sale in UK.
    Uncle Eric is our resident Gallo expert as well as being a home cinema purist and he would recommend that you purchase a set of six identical speakers, or at the very least three identical ones for the front soundstage.
    I mix M&K front speakers with Mission rear speakers moderately successfully and would think that A'Diva fronts and Nucleus rears would be a far better match than mine.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I can't comment on the Divas as I haven't had any to play with but the Due work VERY well with 'ordinary' balls. In fact I find the match far easier / better than matchings from 'conventional' speakers packages. For a rule of thumb I go by what Ian J has written (and is Uncles advice). All the same if possible but at least keep the front three the same.
