Optical wall plates
Trollslayer
I am about to rewire in a house with brick walls and want to put a couple of optical cables in so the question is:
Is there an optical wallplate that will let me use an optical cable buried in the wall?
I have got some right angle adapters but they are so big I can't really get the connectors into the backbox.
Thanks.
Trollslayer
Thanks, I got a sample of those but the adapters are so big the strain relief on the optical cable would still be in the trunking.
It looks like with Fisual cables I can unscrew the connector cover and trim down the body enough to fit in a 45mm backbox.
Sanders79
Crikey, really?? What if you use a 47mm back box and bury the trunking a bit deeper in the wall?
Trollslayer
That's what I'm doing but it's still necessary to shorten the strain relief to keep the strain on the coupler down.
Trollslayer
I'd much rather stick to pure optical - using coax raises the spectre of earth loops and converters mean more bits, cost and points of failure.
It's a pain but being careful means the optical route will work OK.
I'm fitting HDMI 1.4 High Speed HEAC cables so too late to skimp.
Trollslayer
Good idea, there wil lbe 47mm baack boxes for the optical feeds. :smashin:
