Optical Vs Coaxial in a DD/DTS set up
Discussion in 'Cables & Switches' started by Glenzo, Feb 14, 2005.
  1. Glenzo
    Glenzo
    Sep 3, 2004
    996
    32
    Co. Armagh
    +79
    I have a complete separates system :dts: and :dd:
    I've always used Digital Optical as it appeared here in E.U. to be more of the preferred choice/newer technology.
    However, I've heard several people online say that Coax is better.
    I'd like to hear some comments from AV Forums. :lease:
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,805
    Somewhere in South Yorkshire
    +6,416
    I can't tell them apart.
  3. hatcher
    hatcher
    Nope. Neither can I.
    I use a coax for DVD and optical for CD - it just evolved that way.
  4. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Just to add a little more fuel.....
    I've been unable to tell the difference between cheap and cheerful optical and Nordost glass.
    I can tell the difference between rubbish and good quality coax though. Type of connectors also seem to have a bearing on Coax cable. 75OHM BNC is marginally better than RCA. On budget systems you won't tell the difference.
    On some systems I find Optical gives a bit of an analytical feel to the music. Coax seems more natural. This could be psychological though......
    I have to say on some systems I cannot tell any cable apart from another......Make of that what you will.
