optical to phono?
Discussion in 'Cables & Switches' started by Brummy1875, May 7, 2007.
  1. Brummy1875
    Brummy1875
    Dec 28, 2006
    2,307
    3
    +222
    hi can you get an optical to phono splitter? just the basic red and white analogue? thanks
  2. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    They are different technology, so you need a converter, not an adapter. Optical is an encoded digital stream of bits. Phono is just a single audio channel (a pair when you have the left and right channel). So, what you are after is actually a full digital to analogue converter, and that can be expensive. Normally there is an analogue output that goes along with the optical one - easiest is to find that!
    See here for why it's not trivial.
    Greg
