Optical to Coaxial Digital Audio Convertor
Discussion in 'Cables & Switches' started by Nick_T, Nov 26, 2004.
  1. Nick_T
    Nick_T
    Nov 3, 2004
    115
    16
    Cambridge
    Can anyone recommend one of these? I have run out of optical inputs and need to convert my Sky+ optical output to coax.
    I have found this from Maplins thanks to "Nick UK" on these forums:
    http://www.maplin.co.uk/Module.aspx?ModuleNo=29293&TabID=1&source=15&WorldID=2&doy=26m11
    It is £14.99 which is fine, but I am worried about the quality.
    Will I loose much in the conversion if at all? Bear in mind this is Sky+ not DVD source.
    The alternative would be to get some kind of optical spliter where I could plug two optical sources (DVD and SKY+) into one input.
