Optical to Coaxial cable - does it exist?
Discussion in 'Cables & Switches' started by andrewf, Oct 26, 2005.
  1. andrewf
    andrewf
    Apr 26, 2005
    1,031
    48
    +28
    Am I right in thinking that you cannot get this sort of cable?
    I plan to use the component input of my Phillips 9830 for a soft modded Xbox, however the Xbox high def kit appears to be optical and the 9830 is coaxial. The only way I can get sound for my Xbox at the moment is thru the amp. Ok most of the time, but sometimes I only want to use the TV sound.
    Having searched the forum and the web, the best I can find is resorting to op / coax switchers.
    This is a problem for me as they need the small power supply to run them and I have no more sockets :thumbsdow
    Any ideas or am I stuck with this option?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,618
    Rainham Essex
    +2,547
    You can't get an optical to coax lead as they are two completely different signal types. Optical passes light down a cable and coax electricity and therefore to go from one to the other you need hardware conversion, and this will need a power supply to work.
    Mark.
  3. andrewf
    andrewf
    Apr 26, 2005
    1,031
    48
    +28
    Cheers Mark
    Thought as much - guess I'll have to find that extra socket
