Optical to 2 Channel Phono Adaptor?
Discussion in 'Playstation Forums' started by Bigadz, Jun 10, 2009.
  1. Bigadz
    Bigadz
    Jun 5, 2009
    52
    I have read that the PS3 has an optical audio out port. To get sound to my amp (stereo) do I need to purchase:
    1. an optical cable (do they come with one already?)
    2. an optical to phono (2 channel red/white) adaptor?
  2. Korum
    Korum
    Feb 19, 2005
    4,423
    Stockton-on-Tees
    +713
    you'll be wanting an optical cable and there isn't one in the packaging. Your amp will obviously need to also have an optical input. Why did you put (Stereo) in brackets? What amp do you have?
  3. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    That depends on whether your amp has an optical in or 2x phono in.
  4. Bigadz
    Bigadz
    Jun 5, 2009
    52
    My amp is a Teac AH-500, Im not sure it has optical input, will have to look, but its essentially a music amp.
    Is it just as effective to run the red and white phono's direct from the TV to amp or would this give a lower quality than going direct from the PS3?
  5. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    Why don't you just use the cable that came in the PS3 box for stereo? Thats how I have it...
  6. Bigadz
    Bigadz
    Jun 5, 2009
    52
    I wasnt aware what cables it came with? What type of cable is it?
  7. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    Its the normal playstation connector to yellow, red, white phono connectors.
    You can set the PS3 to output the sound on that and the picture over HDMI (which is exactly how I have mine setup as I use a stereo amp).
  8. Bigadz
    Bigadz
    Jun 5, 2009
    52
    Excellent that answers my question :smashin: This way when streaming music to the amp the sound will be spot on. For films it wont be surround but it will be decent.
    I guess it just leaves a yellow cable unconnected?
  9. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    Yeah just leave that dangling as it were ;)
