Optical splitter.
Discussion in 'Home Cinema Buying & Building' started by Blue Triangles, Oct 19, 2005.
  1. Blue Triangles
    Blue Triangles
    Sep 19, 2005
    1,002
    +82
    Can you get a Two input/One output optical splitter cable? I've seen One input/Two output but not the other way around. I have Two optical out sources but only One input on my receiver, meaning I would have to keep swaping the cable over.
    Thanks.
  2. John
    John
    Dec 13, 2002
    11,716
    +3,411
    I used to use a splitter for Sky+ & Xbox into my amp . I just used it in reverse . So long as sky was in standby , I had no issues at all . Switches are available now for about the same money , TVcables.co.uk have them . ( I think thats them)
    John
  3. Blue Triangles
    Blue Triangles
    Sep 19, 2005
    1,002
    +82
    Ok, thanks for the quick reply John. :)
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    Beware ! The optical output on some types of Sky box stays on, even in standby. Worth checking before you buy.
