optical splitter
Discussion in 'Cables & Switches' started by BigGEORDIE, Oct 18, 2004.
  1. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    Hi can anyone help, I bought an optical splitter on the advice of someone on this forum so that I could use it in reverse for my Ps-2 & Xbox. I bought a jesmay one from www.tvcables.co.uk and I can't get the bloody thing to work. I am wondering if they now make them only work as intended ,so that everyone would have to buy the optical switch which costs more. I have a 10 metre lead to my reciever. I was also wondering if I would need an optical booster, I hope not as I am out of plug sockets and adding one would mess up the work that I have done to hide all the cables. Any help would be great.
  2. John
    John
    Dec 13, 2002
    10,931
    +2,620
    I use the MAXVIEW one in reverse on SKY+ and XBOX . Make sure thet both units are not on at the same time
  3. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    mabe the one i got only works one way . how long are your leads
    maybe i need a booster
  4. John
    John
    Dec 13, 2002
    10,931
    +2,620
    Leads are about 1.5mtr , again cheapo maxview jobbies. Get down to B&Q if you can , try out a MAXVIEW one ,if it works :clap: , if it doesn't :confused: . Don't know how they could only get it to work one way . I take it you have DD out enabled on both units ?
    JS
  5. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    yes .the lead from the ps-2 worked the other day for about 2 mins then stopped. the x box lead works great. I think I must have got a dodgy splitter, because the x box half works and the ps-2 half does'nt
  6. John
    John
    Dec 13, 2002
    10,931
    +2,620
    :D but in that case the xbox half doesn't and the ps2 half does :rotfl:
    sorry couldn't resist :smashin:
  7. John
    John
    Dec 13, 2002
    10,931
    +2,620
    try swapping leads over
  8. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    done that . its wierd because you would think that swapping would work but it does'nt. my optical lead to the reciever is 10 meters long but the x box has no problem with it. I wonder if the ps-2 puts out a weaker signal :confused:
