Optical Sound
Discussion in 'Xbox Forums' started by Tom Tom, Feb 19, 2013.
  1. Tom Tom
    Tom Tom
    Nov 2, 2004
    1,563
    Behind the Sofa
    +268
    I was using up until last night optical sound on the xbox from the lead that went from the 360 to my avermedia capture card and then to the TV.
    The Avermedia lead sent the optical signal perfectly.
    However I have now sold that so gone back to my original lead. The optical sound seemed to work on boot up, but then when in the menus and system it stopped.
    Not sure if it is the old lead I am using, or if there is something I am missing?
    Anyone else had this problem?
  2. Harry Clayworth
    Harry Clayworth
    Feb 25, 2013
    24
    3
    i had a problem once when i'd taken my optical out as i was taking my xbox to a friends house, when i got home i plugged the optical back in but i had no sound, i took it out and there was dust on it so i cleaned it and it worked fine again. Ive also had an optical lead die on me as well and did what happened to you, so it could be that.
