It is on AV cable near the end that plugs in to the 360
Is yours a core 360? They have a different cable i think which may not have the optical out.
Premiums all have one similar to the one pictured though
Right....that cable is different to the one that came with my XBOX 360.
There is no optical out put on the part which goes into the xbox, why is this ?
do i need to buy a different cable, like the one in the pic ?
yeh mines core, maybe thats why i didnt get that cable.
what is the exact name for that cable so i can do a search for it ?
also where is the cheapest you know, off hand, where i can purchase it ?
cheers
I bought a RGB scart cable for my 360 and that has the optical port on it as well. I know I use it.
Why it isnt on the console though is beyond me, it's stupid to have to have the right cable to connect another cable?![]()
its not on the actual machine as it makes you buy another cable if you own a core machine, clever ploy by MS to make even more money and buy big Bill another house in the country..........
this the one ? by the way i am using an hdtv..
http://www.play.com/Games/Xbox360/G...x_360_Digital_AV_Component_Cable/Product.html
i have a dell 2407 and it doesnt have any outputs for the red or white cables that come with the component cable so i tried the optical plugged into my pc which has a soundblaster xfi gamer in it with an optical out ,still no sound anybody help
one of these i take it 2 Phono to 3.5mm Stereo Adaptor
my speakers have no other inputs and im not sure about the pcm dolby thing
i thought i could just put the optical cable from the soundcard to the component lead
yeah i going to pick up one of these now ,but will that mean i have to keep swopping leads in the back of the pc
Please dont tell me you are actually using the included Composite Cableas it provides the worst possible picture quality.
If you have an SDTV then you want to upgrade to the Official RGB Scart ASAP as it will greatly improve the picture quality plus it will have the optical output on the plug.
