optical out to usb in...?
Discussion in 'Cables & Switches' started by pixelpidgeon, Sep 7, 2007.
  1. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,552
    +1,785
    morning. just. Been searching all over and cant find inter-connect that will take an optical out feed from a roku m1001 to usb in connection on my creative modx. I plug headphones into the modx.
    Im mainly asking as i have read that the 3.mm jack in on the creative is not as good as the usb in. I appreciate that the creative modx is mainly built for laptop usb out.
    Any light anyone can shed on this would be great. cheers, pixel
  2. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    I have only seen 1 usb / optical feed system and this was from sony and is software driven. SONY PCLK-MN10 USB (I still have one in a box) it allowed you to pass a optical feed to minidisc via a computer. This was very limited.
    Can you list all your inputs and then all your outputs that way I would be able to work out the best way for your equipment. I don't do model numbers that much. ;)
  3. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,552
    +1,785
    hi pixelpixel.
    The source (ROKU Soundbridge M1001) has the following outputs,
    1*Optical, 1* coaxial and 1* Analog 1/8" miniplug (3.5mm jack)
    The output (creative xmod) has the following inputs,
    1*USB and 1* 3.5mm jack (stereo input)
    another option of possibly a better signal from the sounbridge could be optical ou cable with 3.5mm jack converter. Like this here,
    http://www.play.com/Electronics/Ele...l-Audio-Cable-With-3-5mm-Jack-EU/Product.html
    Or a more expensive idea would be to get a good headphone amp (or any amp) with optical or co-axial input, and a headphone out obviously.
    But these are surprisingly hard to source as well! :D
    thanks,
  4. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    Try googling Beresford DAC
  5. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,552
    +1,785
    Gone for this. looks great value. thanks for taking the time hilight this to me. :thumbsup:
