Optical or Coaxial?
Discussion in 'AV Receivers & Amplifiers' started by weyland-yutani, Aug 23, 2003.
  1. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    To connect DVD player to amp, which is best, is there even a difference?
    :confused: :)
  2. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    Coax is better for any digital audio connections.
    Optical is a cheapo option used my manufacturers to cut the cost of building AV components.
    Owen
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    This one has been answered many times and provokes a lot of support from both sides....as Owen says,broadly speaking,coax is capable of potentially better results.....whether or not you notice it is down to the quality of the components you are using....some simply aren't capable of resolving any difference.
  4. Smurfin
    Smurfin
    Aug 13, 2002
    21,422
    +4,354
    :rolleyes:
    You'll notice no difference frankly.
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    When photonic bandgap technology trickles to optical fibres, they will be a far more efficient transmission medium than coax..... anybody arguing simply doesnt understand photonic crystals! :p
    Of course this still will include an additional conversion between optical and electrical which may negate the benefits of the bandgap fibre. But then again, optical signal processing is now possible, it is very likely that devices originating in the optical sense will at some stage become all optical and the coaxial connection will be a poor cousin!
    Ad
  6. Smurfin
    Smurfin
    Aug 13, 2002
    21,422
    +4,354
    ahh but what about the transcendental coaxial reflex signal, which surely negates any need for the optical fibre, although that said once the reflex signal kicks in its simply converted to an optical signal which thus renders the whole argument a bit moot, and the fact is if you've read all of what I've just typed means you have the patience of a saint or you're just plain sad. Go figure.
  7. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Hopefully after that,weyland should be able to get what he was asking from owenw's post....if he has both optical and coax cables available,the easiest way is simply to try both....if one sounds better...stick with that.
  8. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    buns and smurfin: were you two employed by the Wachowski Brothers to embellish the script for The Architect in Matrix: Reloaded by any chance?! LMAO :D
  9. Smurfin
    Smurfin
    Aug 13, 2002
    21,422
    +4,354
  10. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Who said it's a script?
  11. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    its cheaper to get a decent digital coaxial cable (e.g. Black Rhodium Rhythm silver plated digital £15) than a decent optical (Black Rhodium Silver Grey £30) Coaxial also runs at a stable 75ohm signal, which optical doesn't. imho coaxial sounds much more natural than optical.
  12. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    impedence doesnt have much meaning in optical terms..... refractive index and such likes replaces thjat
    Ad
  13. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    I think I'll go with the coax. thanks for the imput, guys:)
  14. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I like that :) It is a pity that virtually EVERY coax doesn't run at anything near 75 ohm and this is completely irrelevant for optical! I won't even mention RCAs.....;)
  15. mjn
    mjn
    May 24, 2001
    22,084
    Herts, England
    +9,828
    didn't know it was April 1st.....
  16. Prav
    Prav
    Jan 6, 2002
    96
    +4
    In layman terms doesn't the optical have to convert the 'light' signal into an electrical one, that coaxial uses in the first place. Therefore coaxial is a bit more pure. Or have I missed the point.
  17. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    i presume that electrical is converted to optical for the optical connection (by the device of course, not the cable). But, dont forget there has already been a conversion from optical to electrical since the disc is read in an optical fashion..... hence we need optical SP :D and then we can forget coax electrical altogether!
    Ad
  18. mjn
    mjn
    May 24, 2001
    22,084
    Herts, England
    +9,828
    c0-ax can be prone to electrical interferance though......anyway, do a search this topic has been discussed many a time before!
  19. Sunday Ironfoot
    Sunday Ironfoot
    Sorry, but I fail to understand how there can be a difference since in both instances the signal is being transmitted digitally, the noughts and one's are either there or they're not. Doesn't the receiver simply re-request data that's missing, similar to how 'packet loss' works over an internet connection?
  20. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    well the signal processing in a player is done electrically, optical processing is bleeding edge stuff that will be a while before it makes it to this level. So the signal exiting the player is natulally electical in nature. So to use optical you need to convert it to optical, which is a potential source of error. Then, in transmission, both routes are subject to loss by interference, loss though a cable when reflection conditions arent met, that sort of thing. There theoretically is error correction, but this is not full proof
    Ad
  21. thackl
    thackl
    Jul 7, 2003
    46
    Sydney
    Hi guys,
    Optical systems can introduce additional jitter because the signal is converted from electrical pulses to light pulses and back again.
    here is the theory I found on http://www.htcentral.net
    "With digital data, there are only 2 considerations, data integrity and timing. If cable distortion or interference or whatever causes the 1 or 0 to be incorrectly received, then the data integrity is lost and you get a gross error (dropout or a pop). If the 1 or 0 is correctly received, there can still be an issue with the timing of the data. With PCM, the timing clock for the DAC conversion is usually recovered from the transitions in the data signal so variations in the incoming clock signal will subtly distort the output waveform. This timing error is commonly called jitter.
    Jitter can be introduced as the data is read and extracted from the DVD (or CD or whatever). With a poor cable it is also possible that distortion or interference may alter the shape of the data signal enough that the transitions are detected by the receievr at the wrong time, adding additional jitter.
    With DD, dts and MLP (I don't know enough about DSD) the data streams are buffered and decoded with a separate clock (which may still be slaved to the incoming signal but will vary less due to the buffering) as these formats compress the data. In this case, the effect of the jitter in the incoming data stream on the output waveform will be far less."
    Here you'll find what happened to a Steely Dan master
    http://www.rogernichols.com/EQ/EQ_2000_02.html
    and here you can find everything about jitter
    http://www.geocities.com/jonrisch/jitter.htm
    Tom
  22. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    But dont forget we are already accepting an optical to electrical conversion without any arguement, the jitter that such a conversion adds must be small else we should be moaning about the first conversion!!
    Ad
  23. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    This was discussed about 18 months ago in a very long and heated thread which by the end had resulted in several members becoming guests.
    I can't find the link now unfortunately
  24. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    But..... the discussion has advanced....... there have been remarkable advances in photonics over the last couple of years.
    I suspect that thread is gone..... was it not a little bit nasty?
    Ad
  25. MattB
    MattB
    May 17, 2001
    189
    Essex,UK
    Hey thackl, thanks for the Roger Nichols link I enjoyed it immensely and own a copy of the CD in question...
    Re- the optical vs coax debate, I use coax within my hifi for minimum jitter and optical between PC and hifi. Why optical? I don't give 2 sh!ts what the jitter is in this connection but I do like to have galvanic isolation between the electrically noisy PC and quiet oasis that is my hifi.
    p.s.
    Arcam owners may not benefit from the electrical isolating properties of an optical connection since their gear is riddled with switch mode power supplies anyway. (the enemy within)
  26. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Oh nobody get me wrong...... id be far more keen to debate the future than the present...... the comparison really isnt fair to make.
    MattB,
    nice thinking on the optical! never considered that myself! Not sure the arcam owners will appreciate though! :D
    Ad
  27. MattB
    MattB
    May 17, 2001
    189
    Essex,UK
    :devil:
  28. Chester
    Chester
    Aug 18, 2003
    3,297
    3
    137
    Peterborough, Cambs, UK
    +517
    No. Digital audio transport is one way only, unlike TCP/IP over Ethernet, which would be pretty useless if it was one way, wouldn't it!?! ;) A separate cable would be required to pass audio or control data back the other way.
    Just to join in the Coax Vs. TOSLink debate, has anyone actually tried swapping over from one to the other to observe the effects? I tried it some years ago with an audio CD and a Wharfedale DVD-750 (all I could afford at the time) as the source and didn't notice any difference at all.
    I'll also add that anyone who believes there is a difference in sound quality with an encoded audio signal (such as Dolby Digital or DTS soundtracks) is gravely mistaken. A temporary loss of data down to any small degree is extremely noticeable with large amounts of audio artifacts that are rather loud and bite at your ear drums! Anyone who has experienced a cable not being plugged in correctly or a cable breakdown will know exactly what I'm talking about.
    However, this is not true of CD audio. The way that digital data works for CD audio infuriates me. You can hear differences with different cables for CDA. Why something hasn't been invented to ensure that 100% of the CDA's details have been passed to the DAC at all times is beyond me.
  29. GAmbrose
    GAmbrose
    Jul 5, 2003
    997
    43
    Essex
    +184
    Quite frankly, anyone who thinks they can hear a difference between the 2 cables is either the bastard child of Batfink and Superman or simply deluding themselves.
    Gary A
  30. Craig Summers
    Craig Summers
