Optical or Coaxial DVD connection - which is best?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Pacifica, Jan 23, 2001.
  1. Pacifica
    Pacifica
    Hi everyone,
    I have a Pioneer DV-525 player and a JVC Dolby Digital/DTS amp providing both co-axial and optical connections... I was informed by the guy in the shop (small local a/v dealer) that co-axial connection was better SOUNDING than optical... what do you lot reckon? My decision to buy an optical connection lead is based on your views! [​IMG] any opinions appreciated,
    Stephen
  2. Guest
    Have alook at the 'Update on Coax v Optical' thread under amps & receivers.
    My DVD's on E-Bay
  3. bradavon
    bradavon
    I would say that there isn't any difference, except Optical produces less noice.
    Which is why I have gone for Optical.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Coax is supposed to sound warmer / more natural than optical.
    Besides that they are less sensitive (more robust) and the signal does not have to undergo additional conversion (from electrical to light and back) which may or may not effect the sound.
    Unless you have problems with a ground loop (causing noise/hum) I would always go for coax, but make sure it's of a digital type (ie 75 Ohm impedance).
    Rgds,
    Reiner
  5. Mad Max
    Mad Max
    Check out the Amplifiers and Receivers Section Update on Coax v Optical Thread...
    And
    http://www.taralabs.com/reviews/digital.htm
    It's all there.
    Guys, please try to use the SEARCH facility of the site... We all have something to gain from more educated questions
    An adult is just a kid with expensive toys.
    Rui
