Optical Inputs
Discussion in 'AV Receivers & Amplifiers' started by 1ofaKind, Jan 6, 2005.
  1. 1ofaKind
    1ofaKind
    Dec 16, 2002
    233
    Midlands
    +4
    Hi All,
    Is it just me (or am I stupid :laugh: ) who struggles with the number of optical inputs on amps. I've got a 3802 atm which has 3 optical inputs. Currently I have Xbox,PS2 and DVD player hooked into them. Now I will most likely be moving to plasma and will have the following to hook up.
    DVD Player , PS2 , Xbox , Laser disc (I could shelve this but one sunny day I may use it), Sky+, PC (from soundblaster), maybe DVDR and of course in the future PS3, Xbox2, Blu-Ray etc...
    So whats the best way round this problem (the only amp I found with a good number of inputs is the Z9 but it seems overkill for my smallish room with Kef Eggs :blush: ) - I suppose I could save one by getting a new DVD player and amp and using I-Link.
    Is it only me thats suffering??? :eek:
  2. MagicBoy
    MagicBoy
    Sep 19, 2003
    307
    +20
    Do you have any co-axial digital inputs you can use? The Xbox, PS2 and Sky+ are optical only IIRC, but most DVD players and the SoundBlaster cards can output an electrical digital via co-ax.
    Another option is an optical digital switch eg this to create three inputs one connection to the amp. It's also a bit cheaper than a Z9 :D
  3. Poolsharkie69
    Poolsharkie69
    My Yammie 1500 has lots of optical inputs...check out yammys webiste...and all major manufacturers should have good pics of the back of their amps on their site.
