optical input
Discussion in 'AV Receivers & Amplifiers' started by cradleoffilth, Apr 25, 2003.
  1. cradleoffilth
    cradleoffilth
    i have just got a panasonic receiver and i have connected my dvd player to it using the optical output. the only poroblm is that is doesn't work on the optcal output. the receiver works on analogue but not optical. i have set up the receiver and my dvd player but it still doesn't work. the optical output is on because i can see a red beam from the socket. please help!:(
  2. MikeK
    MikeK
    Try it on the input instead :)
    If a receiver has an optical ouput, it's usually meant for attaching a minidisc recorder, so you can record!
  3. cradleoffilth
    cradleoffilth
    sorry:blush: my last post was a bit unclear. my dvd player is connected to the input on the receiver.
  4. jont
    jont
    Apr 8, 2002
    4,197
    near Aylesbury
    +528
    Do you need to tell the dvd player to route the audio through the optical output ?
    or even to reassign the audio input on the 'dvd' setting on the amp to use optical instead of analogue ?
    the optical outputs will glow red even when they are not being used ...
  5. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    Aldershot, Hampshire
    +286
    I had a similar issue a while back and it came down to the fact that I hadn't changed the source setting for the channel i was using from coax to digital optical within the amp menu. I changed it and hew presto every thing worked a treat. If this doesn't work try a different toslink cable or connect your dvd by the coax out instead (if it's got one).
