optical input on 360 ?
Discussion in 'Xbox Forums' started by andy_mfc, Mar 15, 2006.
  1. andy_mfc
    andy_mfc
    Dec 11, 2005
    240
    Middlesbrough
    Hi ppl quick question needing a simple and quick response. can somebody tell me where the optical input is on the 360 thnx ? i wanna rig it up to my new cinema system i have coming
  2. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    it plugs into the back of where the cable comes out of the xbox
  3. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    any recommendation where to get one of these optical digital cables? I was looking in curry's and they seemed expensive to me, £12.99 the cheapest and a Belkin for £39.99 :eek:
    Are these worth the money, will you notice a big improvement in sound quality? What did you pay for yours and from where?
    Sorry for questions guys - i just wanna know if its worth me splashing that amount of money on one of these leads, ya know :D
    Blue
  4. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    www.tvcables.com
    They have them on there for about £5. That's what I have.
  5. red severn
    red severn
    Feb 6, 2004
    163
    +9
    you need to buy either componant or vga cable and optical cable comes with it.
    regards red.
  6. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    I'm assuming you have a DD 5.1 kit.
  7. nick501
    nick501
    May 6, 2005
    7,217
    Walsall, West Midlands
    +782
  8. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
  9. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    ebay sell those cables, mine was less than £5 on there
  10. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    You could also have looked at the FAQ at the top of the page :D. On this page it show pics of the cables. The optical bit comes out of the fat end of the cables which connects to the XBOX, i.e. top right of each picture.
    Andy
  11. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    Thanks for the link mate. Nice price. I have ordered one :D
  12. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    there is no optical input on the xbox 360. There is an optical out socket on the HD and RGB scart cable.
  13. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    I just checked and its on the MS component cable
  14. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    A.K.A HD cable! :D
  15. OldAndSenile
    OldAndSenile
    Nov 30, 2005
    564
    28
    +55
    When you look at optical cables, try and get one with largish tabs on the side to lock the cable into the HD lead.. I had to change my optical cables round from my DVD player and my PS2 because the other ones just kept falling out of the 360 optical slot - it seemed to be fractionally bigger for some strange reason?
  16. michaelT1888
    michaelT1888
    Jan 26, 2006
    830
    South Lanarkshire, Glasgow
    +13
    anybody have a decent suggestion for surround sound?
  17. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    Got mine working but it doesn't seem to be a very good fit into the MS component lead. It could easily fall out?
  18. Cookie3004
    Cookie3004
    so would i get significantly better picture using the 360 for my DVD playback than my Pioneer 636 dvd player, as the 360 will output in HD (just got a HD RP tv.) and my pioneer wont,
    what was holding me back was the lack of optical but with a component cable on route i should be able to do optical 5.1 with either now.
    which is ht ebest option have heard mixed reviews of the 360 for dvd playback.
  19. doink
    doink
    Elaborate
  20. 5to1
    5to1
    Nov 21, 2005
    2,929
    +758
    Should I have got one with my premium then?
