Optical input information needed
Discussion in 'AV Receivers & Amplifiers' started by johnywh, Mar 16, 2005.
  1. johnywh
    johnywh
    I hope this is the correct place for a question - could not find any answer with a first search:
    I have an amplifier capable of DTS/DD with coax/optical input and i want to connet the audio of an external DVD player.
    The question is how to connect the audio output of the DVD to my amp in order to have the correct audio format - that can vary from MONO to STEREO to 5.1 or even DTS.
    Is the optical interface plug and play? Is the interface capable to tranfer any type of signal - i suppose yes.
    Is the amp capable to understand the signal type and decode it correct? Is there any specific protocol used for that?
    My amp is SONY DAV D800 a compact DVD/amp/receiver system but i suppose the answer will be the same more or less for any system.
    Thank you
    John
  2. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    Yes, digital inputs should be plug and play. The data stream contains flags that tell the decoder how to handle the data.
  3. Rolo Tomasi
    Rolo Tomasi
    Dec 13, 2002
    215
    +4
    Just link the two with an optical cable. It will transfer whatever signal is passed to it by the dvd player, be it 2-channel, 5.1 etc. The amp will decode it although you may need to select the output you require or else the amp may use DD prologic, DTS Neo6 or whatever. Most of this stuff is usually stated in the manual. If all else fails, try reading it.
  4. wishy
    wishy
    Jan 23, 2005
    105
    19
    Boldon, Newcastle, England
    I find, being a novice, manuals do nothing but confuse even more. Advice on these forums seems to explain much better. In laymans terms!
    God bless you all, and may the force be with the forum!! :clap: :D
  5. johnywh
    johnywh
    for the answers, i doubted about how clever is my system, i will try and see. The manual does not say anything (what a surpsise!). The only reference is in a drawing saying that "this port is optical input" - no info if this input is for audio or video or what to connect there.
    BTY, searching in the net i found out that this interface is named S/PIDF or IEC-958 and the FO cable used is toslink.
    thank you again
    John
  6. Astaroth
    Astaroth
    Jun 22, 2004
    3,708
    London
    +898
    The one other thing to note is to make sure the DVD player is set to send the information via digital as bitstream rather than PCM
