Optical connections for Denon A11SR
Discussion in 'AV Receivers & Amplifiers' started by jimcarney, Oct 17, 2003.
Tags:
  1. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    I used to use the optical connection 1 for TV which enabled me to use my XBox in 6.1 ,now Ive just had Sky+ installed Im using the same connection for it .How do I assign another optical connection for the XBox because when its on I am still getting Sky+ through it . Thanks in advance .Jim
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,443
    United Kingdom
    +1,821
    From the OSD main setup menu, you need to go to Digital In Assignment and assign the relevant inputs - OPT 1, OPT 2 etc etc
  3. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Thanks Jase , Ill have another go Ive tried to do that a couple of times already . Thanks again. Jim
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,443
    United Kingdom
    +1,821
    You'll need to assign (for example), DVD to OPT1, CD to OPT2, TV to OPT3 etc etc. :)
  5. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Jase, solved it evetually had to select imput as as auto after assigning optical output . Thanks again. Jim
