Optical Connection
Discussion in 'AV Receivers & Amplifiers' started by Adderson01, Jun 26, 2002.
  1. Adderson01
    Adderson01
    Newby question but I can't find the answer in the FAQ's.
    If I coneect my DVD to my Amp using the optical in & out should I get sound or do I also need to coneect using a twin pho connection as well?
    When I conneted with just the optiacl lead nothing but as soon as I connected with the phon's as well the sound came on.
    I have checked that the amp's set up for the digital connection and it does sound better than just my phono connection into my Digibox but I want to make sure,
    Cheers in advance.
  2. Jase
    Jase
    Mar 16, 2001
    10,830
    United Kingdom
    +2,723
    You should get sound from the Optical, you dont need to have it connected via phono leads as you´ll only get an analogue signal. Check you have the digital output of the dvd player set to Bitstream.
    cheers
  3. Adderson01
    Adderson01
    Brilliant,
    It's the simple things that please you most.
    Just swapped it and it sound excellent now.
    Thanks for your help.
    Adderson
