Optical connection
Discussion in 'Arcam Owners' Forum' started by Andrew K, Jan 10, 2005.
Tags:
  1. Andrew K
    Andrew K
    Oct 14, 2004
    3,385
    +608
    My optical connection between Sky + and AVR300 has failed in that no sound comes through at all whether DD or stereo.
    Testing all elements seems to indicate that the Optical cable is the fault as using the same cable from the DVD results in no sound either. Changing the optical connection on the AVR results in no change either.
    Finally I tried another optical cable yesterday and that worked fine.
    I noticed that the red light coming through the cable was much dimmer on the problem cable.
    Has anyone come across this before and are there any solutions other than just buying another cable. The cable used is Chord's Optichord.
    (posted on cable forum as well as arcam forum)
